USB File Transfer🔗
Session data and video files can be transferred directly from your iOS or Android device to a computer via USB cable.
iOS Devices🔗
- Connect your iOS device to your computer using its USB data cable and open iTunes.
- Select your device using the device button near the top of iTunes.
- Navigate to the File Sharing section and select TrackAddict.
- Select the desired
Log-files and save them to your computer. Files can be dragged directly into a folder. - The
.CSV(data) and.MOV(video) files are pre-synchronized and ready for use in RaceRender.
Android Devices🔗
- Connect your Android device to your computer using its USB data cable.
- Set the device to MTP file transfer mode by swiping down from the status bar and selecting "MTP", "File Transfer", or "Media Device".
- Open the device's file system using Windows Explorer or Android File Transfer (Mac).
- Navigate to
Android/data/com.hptuners.trackaddict/files. Devices with an SD card may show two similar storage locations. - Select the desired
.CSV(data) and.MP4(video) files are pre-synchronized and ready for use in RaceRender.
File Management Notes🔗
Adding, removing, or renaming files via USB is intended for advanced users only. Please observe the following:
- Session files must follow the naming format:
Log-yyyymmdd-hhmmss yyyymmdd— year/month/day (e.g.,20110817for August 17, 2011)hhmmss— hour/minute/second (e.g.,154312for 3:43:12 PM)- Supported file extensions:
- Data:
.csv,.tad - Video:
.mov,.mp4 - Session notes:
.txt - The video file name must match the data file name exactly, differing only in extension (
.movor.mp4instead of.csv). - Files not created by this app, or files that have been modified externally, may not function correctly. For rendering external data or video, refer to RaceRender.
- The app should not be on the Sessions screen or any of its sub-views while session files are being modified, as this may cause errors or data inconsistencies.
Tracks.datcontains Circuit mode track records;Segments.datcontains Segment mode tracks;Trails.datcontains 4x4 Trail data. These files can be copied to or from other devices running the same version of the app.- If
Tracks.dat,Segments.dat, orTrails.datare modified or replaced, it is strongly recommended to fully restart the app. In all cases, navigate to the Track Selection screen and reselect the desired track to ensure data is refreshed. - If issues arise, restart the app as a first step.
- As a last resort, copy all files to your computer, remove them from the app via USB, restart the app, and re-add files one at a time to isolate the cause of any issues.
